Diesel loco with sound
(In Topic #13533)
How do I play all the sounds including start up
Hi All. I have some diesel Locos with sound, but I cannot play all the start up sounds like priming and the compressor. And with the NCE POWERCAB how do I get to the higher numbers? Is it Something to do with the “ Shift Key? Best wishes Kevin
Press option once gives you 13-19, just press the number you want (3-9). 10 is automatically added.
Press option twice gives you 21-28.
Prog/escape returns you to 1-12.
Important: Make sure the option key is programmed to 122 using cab setup. The default value is 94 (brake), change it to 122 (extended function). See pages 18-19 of the manual. Follow the instructions.
As you (Kevin) surmised, there are other key shortcuts/combinations that work as well, but this solution works better for many of us.
