Braking from the handset
(In Topic #14077)
According to a YouTube video
Hi All. Browsing online the other day, I came across an interesting claim. According to the reviewer the decoder/chip arrangement in the Loco meant that you could apply the brake and the Loco would come to a halt. Was he “pulling my chain†or can this actually be done? Best wishes Kevin
I guess one could programme one of function buttons accordingly to be a brake on any brand of DCC controller.
Yes the latest Zimo decoders have this function built in and very authentic it is - the longer you press F2, the harder the braking. Tapping it gives intermittent braking as one might use just to slow the loco.
I ran into this limitation yesterday when blowing a new sound project from YouChoos onto one of my Heljan class 33 locomotives. The project went on to the Zimo MX645 with no errors, but the brake on F2 didn't work, and neither did any of the functions above F19. On checking the decoder, it showed it was version 30. Corresponding with John Guymer of YouChoos (who is always extremely helpful), we worked out that I needed to update the decoder software. I downloaded the necessary files from Zimo's website and duly updated the decoder this morning, and all of the functions now work as they should, including F20 - 24 and F27 and F28 (F25 and F26 are not used on this project).A bit late with a reply, but with Zimo decoders v37.1 and up you can close the throttle and use (Usually) F key 2 to slow or bring a loco to a stop. I don't know about other makes. This is usually done with F 2 but can be mapped to other keys. The main reason, besides convenience that F2 is used is because NCE uses it as default, as Ron says. With my Lenz controller, I can set any key to be lockable (stays on when pressed and released) or not.
I have seen a few other projects that use other function keys for the braking (one uses F5), but these things are all remappable anyway. Using and NCE cab would require frequent double presses of F5 (or whichever key is required) to engage and release the brakes. Using the standard F2 means the horn/whistle button can be used because that is the only non-latching button on the NCE Power Cab/Pro Cab throttles.
Learning from seeing it in operation I set about getting my PowerCab and a ZIMO Chip set up and these notes are as much an aide memoire as anything but may be useful if others tread this path. Thanks to everyone here whose posts have helped me.
NCE PowerCab
This has all the functionality required, just a few tweaks to make various Keys more useful, some (*) are optional things I did for my convenience. Once I had these in place and working, the keys were relabelled (thx Sol) for ease of recall.
"OPTION"
by default this activates the NCE Brake in one press. I discovered that having this can be useful to take the Throttle immediately to "0" rather than multiple presses of the "Dec Fast" when using ACTIVE BRAKING. Just relabelled to "CONTROLLED STOP" to reflect its purpose.
Access to F10-F29*
I decided to use "Shift-Momentum" mainly as its handy up there and not used otherwise. It duplicates the tiny "Expn" button that I can never remember
"ACTIVE BRAKING"
As suggested here, the non-latching F2 whistle button is a good one to use for Active Braking. Changing the action of F2 is done via the CV settings on the DCC Chip - below.
"WHISTLE"*
With this now removed from its dedicated button I decided to reassign "BELL" to F6 my primary Whistle, it is however latching. This is done via the Cab Parameters Setup (PROG 6)
As shown here:
Changes to ZIMO CVs
F2 Key - The Whistle function is removed from F2 by setting CV #516 at "0" (originally "048")
F2 Key - Assign the "BRAKE" Function here by setting CV #309 at "2" (originally "0")
Modifying Deceleration CVs
CV 4 (non-braking mode) is set to very slow decel. CV4 ="100"
CV 349 (braking mode) is set to high decel. CV349 ="10"
Operating in "Active Braking" mode.
At cruising speed use the throttle to dial back to the target speed required after braking (this is the critical bit I missed! - perhaps because it's assumed). Nothing much happens other than motion sounds back off. Then pressing ACTIVE BRAKING will shift deceleration to the CV 349 rate as long as the button is pressed.
From there braking can continue more slowly or driving resume as required. I appreciate that for some this write up might qualify me for the Sybil Fawlty Mastermind prize - for Subject "The Pleeding Obvious" but at minimum it'll help me work through my growing suite of ZIMO chips to upgrade them.
Last edit: by Colin W
:pathead
Thx Peter,Well I found it useful Colin so it was well worth it. :thumbs
appreciated,
