Is there a Tool?
(In Topic #11990)
This is my Blacksmith MR Milk van:
There might be some useful info here:
http://yourmodelrailway.net/view_topic.php?id=12498&forum_id=150
If the sides are flanged be careful that you don't cockle them when bending.
http://www.scalefour.org/forum/viewtopic.php?t=1415
My kit had lousy castings (most kits seem to suffer from this I've found) and I had to scratchbuild the steps.
In lieu of rolling bars, copper pipe of various diameters from the hardware store plumbing section and an underlay of dense foam (Michaels) works adequately. I got a set off my local plumber and his collection of copper pipe off-cuts. The more resilient and thinner the foam, the shallower the curve. Why kit manufacturers can't put the proper tumblehome in beats me. Comet coach sides always came with this done.
You'll need a 1.5"-2" diameter pipe for a tumblehome, thin foam, and some sort of jig to keep the side fixed, the bar straight and a stop to prevent the pipe rolling onto the vertical part of the side. Or you can just eyeball it.
