Original Superquick Elizabethan Cottages kit - series B No. 28
(In Topic #12811)
The build of the original Superquick kit
Another build of an original 60s-70s Superquick kit. This kit was replaced by a completely different Elizabethan Cottages kit in the 1980s, but is still, so far as I can tell, fairly easy to come by.There were a few issues with this build. The main one being that the card was slightly warped from long-term storage. Another issue was that the printing on the windows was not very good – but a little late to complain to the manufacturers about that!
The Original 1960s Superquick Elizabethan Cottages – The kit
The whole kit unpacked
Fixing in the windows. I use sticky-tape to get the windows in the correct positions, then add blobs of PVA to provide a permanent hold. On this kit the walls are folded in half to create a double thickness of card. I found it much easier to fix the windows in place before the wall was folded. Also, on this kit, I removed the tape once the glue had dried and added more glue where the tape had been.
All the walls with the windows and doors in place. There are still two walls to fold and glue, When all the walls were glued, I left them overnight under some heavy books.
Yes, bits of wall and card are being used to hold the triangular supports in place whilst the glue sets. In the middle-front the central wall is ready to have the two sections of card added which will support the roof and wall.
After holding each part by hand whilst the glue took hold, I left the walls supported like this overnight as the glue set.
The white card strip in the foreground should be fixed under the overhanging fronts. Unfortunately, I used one half for my glue-pallet. I decided it would be better to cut some board to create a whole floor as this would make the model much stronger. The floors were slipped into place and then blobs of PVA were run around the top edges and underneath behind the front wall.
More supports were added underneath,
and in the top to stop the walls from bowing inwards.
The roof sections were fixed into place by blobbing PVA on the inside of the walls, the roof then being held in position and the whole building tipped up-side-down to allow the PVA to run onto the roof.
The parts and instructions for the chimney.
The two parts of the chimney assembled and glued. The wrap for the upper chimney was a little short leaving a bit of white on the exposed face.
After assembling the two halves, and cutting the base to about the right angle, some fine abrasive paper put a better edge on the bottom. This was then fixed to the roof by blobbing PVA on the inside and letting it run down onto the roof. I did some Ebaying while holding the chimney as the glue set…
The finished building. Ridge tiles added and all edges and exposed card painted in with black watercolour. I think by painting, it really transforms the look of the model.
Painting around the window and door frames, and under the roof in the middle, would have been MUCH easier before assembling the model!
The final view of the finished model.
Another enjoyable build, and not too many problems…
Thanks very much for looking.
Gordon :-)
Barney
Barney
Thanks for the nice comments – much appreciated.
Gordon :-)
BR Blue Post Tops
Thanks for the nice comments.
Glad to hear that I am not the only one with unmade kits knocking around!
There are a few old Superquicks on a well known auction site at the moment – and there's a couple I've got my eye on. I think that they compliment the old Triangs that I've been accumulating lately.
Gordon :-)
I know it's over a year since you did this post but it's the reason I've just joined the forum! I must thank you as - would you believe it - I too bought one of these kits a long, long time ago and just never got round to building it….until last week! As I've explained in my 'new member' post, I've been stockpiling a number of kits over the years (mainly bought with Christmas money from the kids!) and my recent operation convinced me that the time spent in front of the TV recuperating could be usefully employed building some of them. The Elizabethan cottage was the first and I soon discovered that during the period since purchase, the instructions and glazing sheet had disappeared! Thanks to good old Google, I found your article and was able to assemble it - though I had to use some left over glazing from some other kits, which I think will need replacing at some stage, especially the two main windows as you can see! The chimney could also be improved! :???:
Finally finding the time to indulge in my favourite hobby.......that Hornby Dublo 3-rail train set is a long time ago!
Andy
Andy
Thank you very much for the nice comments.
Part of the reason I've posted some Superquick builds is that there is not much information about the kits on the net, so I'm very glad that you've found it useful.
As I believe is quite common, I've got a collection of projects in waiting too, as well as a few that have been in progress a very long time!
Good work on the build. The chimney is a bit of a pain on this kit - the wrap around bottom not meeting up very well. Removing a portion of the bottom and using sand paper to true it up did help rescue mine.
Another supply of clear plastic might be some packaging from kids toys?
Keep up the good work and thanks again for the feedback.
Gordon :-)
