Ready made base-board table
(In Topic #6642)
"Good to know
The table is tested and approved for occasional indoor use only.
Be sure the legs are properly secured under the table top when folded up."
Maybe not too clever for baseboards. Maybe the top would be useful.
Rather pricy for a light-weight (small) table. Better to take that money down to the timber yard and buy more for less:thumbs
Ah, Tim, I have been to two serious [one chopped-off thumb, one partly severed forefinger] D.I.Y. accidents to assist the Ambulance Service in my time.
Not everyone has our remarkable manual dexterity, our comprehensive tool-kits or all-encompassing grasp of material technology….
….hang on…er….oops! I've just stitched two fingers together trying to open a tin of pilchards with SWMBOs sewing machine….
I'm not sure Tim because I haven't bought any timber in the UK for 20 odd years but I have a feeling that it's quite expensive now.
It doesn't grow on trees any more……….
D
[user=2]Robert[/user] wrote:I'm not sure Tim because I haven't bought any timber in the UK for 20 odd years but I have a feeling that it's quite expensive now.
D
I'm sorry, I'll re-phrase that for grammarians and speakers of English……..
"It no longer grows on trees".
[user=312]dooferdog[/user] wrote:[user=2]Robert[/user] wrote:I'm not sure Tim because I haven't bought any timber in the UK for 20 odd years but I have a feeling that it's quite expensive now.
D
http://www.lidl.co.uk/…uk/hs.xsl/index_23441.htm
Available from 22 August in the UK at least.
You can definitely say that again. I've just had a quote from one big name merchant for 9mm birch ply (8 x 4 sheets):
£22.95 per sheet (2)
£20 per sheet for cutting
£25 per sheet for delivery (its classed as a heavy item!)
Total cost: £67.95 per sheet.
Probably easier to cut down the tree yourself!
Last edit: by Mythocentric
Ooh! Look! The end's fallen off!
Colour In The Real World
http://yourmodelrailway.net/view_forum.php?id=175
Buildings For Slitheroe
http://yourmodelrailway.net/view_topic.php?id=10981&forum_id=14
Seeing Phill's mention of decorating table reminded me of one of my attempts at portable layouts, a table similar to this one
http://www.diy.com/nav/decor/decorating-supplies/wallpaper-tools-accessories/decorating_tables/B-and-Q-Fibreboard-Top-Paste-Table-Natural-Colour-9371195
Main problem I found was the width at about 22 inches was a bit tight on curves, it would have meant single track unless one was prepared to go for 9" radius curves on the inner track.
Having got the thing though, it was quite sturdy compared to cheaper ones, that I tried with 2 sheets of 4'x2' 2" thick foam insulation which was a bit better but not much, main bonus I got from it was experience with foam insulation sheets which I've used on Purbeck.
Hello rector!
If you go to B&Q, you get the first 15 cuts for free!
Then, depending on the size of course, it could fit in the car.
I am in the process of building a new set of boards for my club,
for exhibition use, which is all ply construction (plus legs).
The boards are 4' x 2' x 9" (3 of them), 1 sheet of 6mm ply with
all the cuts, £18:95, and it would have fitted in my daughter's
Corsa.
Jeff
Last edit: by jcm@gwr
Jeff
Hello Jeff[user=1459]Mythocentric[/user] wrote:Hello rector!
Corsa.
Jeff
Now therein lies the problem. First I don't have a car. In fact, I haven't driven since some kid in a BMW, who turned out to be both underage and uninsured side-swiped me as I was leaving a roundabout for no other apparent reason that I was (Quote) "In his way!", so it has to be delivery.
In addition to which, we don't actually have a B&Q in Morecambe, the nearest being in Lancaster. You'll gather that Morecambe is somewhat lacking in certain aspects for railway modellers. Luckily for me, my landlords just told me about a trade supplier he deals with and has offered to pick the ply up, ready cut, and drop it off for me! So hopefully, problem solved!
