Legs or Trestles ?
(In Topic #6017)
Whats yourbpreference for an occasionally portable layout
Just wondered if members had a particular preference for how their layout was supported ?
If you have a home layout that may just occasionally go to a local show what would your preference be from the following list?
1 Supported on Folding Wooden Trestles
2 Supported on Extendable telescopic metal stands
3 Supported on Pairs of Wooden legs strengthened with cross braces
4 Supported on Individual Wooden Legs
5 Supported on a purpose built stand
6 Baseboard placed on tables supplied by venue or taken from home
7 Any other method ?
Of all these ways has anyone had any particular good or bad experiences - I know I have seen layout trestles collapse when they were not designed strongly enough to carry the weight of the layout or boards that been pushed off their supports by the spectators in front of a layout that had no protection from crowd barriers.
Finally any tips on construction methods for trestles or legs etc,
'Phone a cabinet maker?
I intend to exhibit Much Wittering by invitation and that is the main reason I've been making it lightweight.
I will either use the venue's tables or take suitable tables myself.
… always with crowd barriers.
However, I get the feeling you are a leg man, Richard.
My layout, Much Murkle is an terminus to fiddle yard layout designed to be erected permanently at home but is freestanding and portable just in case anyone would ever consider it good enough to exhibit in the future. Of course that would rely on me finishing it which is another matter altogether :roll:
The boards are made of 6mm ply and are 250mm deep. The 50 x 50mm legs are in braced pairs and locate into sockets the full depth of the board. The legs are a snug fit in the sockets and there is little movement. Each has adjustable feet so the the layout can be levelled easily.
The first board has legs at each end and the other boards just one pair. I haven't found a need to brace the pairs of legs together along the layout. They seem quite stable, although they have not been tested in any other environment yet.
Personally I would be wary of legs that are not fixed to the layout by some means in an exhibition environment. I'll be very interested to hear the responses on this from those here who do exhibit their layouts such as ElDavo and Dukedog to mention but a couple.
You are getting to know me far too well Peter :oops::oops: but dont tell SWMBO !!
I didnt mention that Lesspoint has its own purpose built metal framework stand which slots together like a market stall that the baseboard sits on but when you add all the pieces that make it up together the weight is quite substantial - but it makes a good solid base though.
Last edit: by Wheeltapper
I had exactly that type of stand made when I was building Pontymister Docks for exhibition use. It cost me over £240.00 for a 12ft x 12ft (outside dimensions) square which is 2ft wide all round. The advantage of it is that it can be made up into dozens of different shapes.
Sadly it will now probably never be used by me and I will end up selling it at half it's cost exclam:exclam:
If anyone is considering such a stand, don't order one until you have contacted me. :roll::roll::roll:
Nigel:cool wink
Yes they are heavy. Yes they are expensive(ish). I didn't price the cost of timber to build my own for Waton 'cos after much thought I changed my fiddleyard plans so I could use the steel jobbies. The timber, hinges and sundry fittings would have cost me a fair bit and frankly my woodworking is no good.
The big plus for these things is that they are immensely stable. They can support up to 150Kgs each and are fairly rigid. The layout just doesn't move when sitting on them and that is what I am after. I don't clamp the baseboards down they are stable enough under their own weight (which isn't much).
One huge bonus I hadn't really spotted when I started is because the trestles are so stable you can bolt/clamp lighting rigs etc. to them. No need for the lighting gantries to reach the floor and no need to have it fixed to the baseboards. Similarly control panels, storage boxes and other stuff can be clamped on.
If you can arrange for legs to fold into the baseboards then these obviously take up the least space though of course it makes the boards heavier. The steel trestles do take up a bit more space than folding wooden trestles but not a great deal more. You can easily carry two of these at a time so the weight isn't that bad. Of course it helps if you have a van or people mover to shift the layout in. ;-)
It's a case of you pays your money and takes your choice.
Can I ask the width of those trestles please ?
(Or if they were laid on their side, how tall are they…) ?
Ta
Stu
Dave,
Ta
Stu
Stu,
I just went down to the shed and measured one of the latest ones I acquired. When fully folded and telescoped i.e. the top bar down as low as possible the dimensions are:
Floor to top bar: 82cm
Across the top bar: 68cm
Width/thickness across the folded legs: 19cm
Somewhere in there is probably the dimension you are looking for. Looking at them end on as they are loaded in the car the width of each is approx 19cm. The ones in the car are not fully telescoped down and have been left at layout height.
The screwfix price is currently still considerably less than the price wanted by some of the baseboard suppliers for ready made wooden layout legs or trestles.
Thanks for the measurements. The 68cm is the important one, to see if the trestles would fit in the estate car against the side window ( where yours are but in a boot with less height, so they would be laid down on their side).
Stu
Nigel:cool wink
:cool winkNigel
http://www.google.co.uk/products/catalog?hl=en&q=trestles&um=1&ie=UTF-8&cid=9403748994274930754&sa=X&ei=DT5uTeyTOoamhAf1xJEw&ved=0CFcQ8wIwAw#
http
Last edit: by ddolfelin
As an alternative, this might be worth considering - leaves plenty of storage space under the layout:
httpkyHooks.com
Hmmmm…. this is a better link…
http://www.skyhook-gb.com/ :thumbs
