Fixing cork to baseboards
With curves this tight.
I cut a very narrow V slot about 3/4 across the strip width and form the curve. The slots close together as the curve is completed.
It takes a little trial an error and if you made a slot to big just fill it with left over cork you have cut for the slots before the glue sets.
I am using that copydex which smells like cat's pee?
Think I would prefer to get high on evostick?
I suppose Peter regarding your track bed.Could you cut out strips of your cork sheet either side of the track to give the illusion of a track bed?
regards,
Derek
Last edit: by shunter1
The way I lay underlay on a curve is to cut it in half, lengthways, draw the centre line of the track, then lay the underlay to the centre line. If the underlay wont bend the curve is probaly too tight ;-)
Paul
I shall try your method.
It seems a better solution.
regards,
Derek
I fix both the cork and the Pastazote down with Copydex.
I covered the whole baseboard on my first attempt of my layout and will do the same again this time as well. It is all down to your own preference though. After you lay it down, then yes, you lay your track straight on top and can also ballast, paint or whatever on top of it as well. I will use neat PVA to stick the cork down onto my plywood baseboards.some people dilute it and I tried that but found neat PVA works best.
Also, shop around for the cork itself if you have not already bought it. I don't know what size your layout will be but you can get 10 m x 1 mcolls on the internet ( from Poland ) and even with the shipping it works out a good bit cheaper than buying the smaller rolls from UK hobby shops.
Good luck
If the ballast - or track pins etc. - come into direct contact with your board top, you've lost your sound insulation ………………hence covering the whole board first - oh, and don't forget to remove the track pins once the track is "fixed" in place (either by the ballast or with glue) :roll::roll:
Derek.
I agree that when Cork is stuck down with PVA it does not have much sound deadening effect for the reasons given earlier.
However, when stuck down with a latex adhesive such as Copydex and the track bed and shoulders formed with Plastazote, it most definitely does reduce the 'drumming' effect caused by sound being transmitted to the board top which then acts like a drum skin and amplifies the noise. I don't want a totally silent layout, that would be impossible. There is sufficient realistic 'atmospheric noise' generated by the wheels running on the rails and the 'clickety-clack' as they pass over joints without having it amplified so that it sounds like a load of marbles being rolled around in a tray.
My track was originally laid straight on the board (which I am led to believe is what quite a lot of people do), using Copydex.
It's only because I wanted 'rod in tube' point control and needed to raise the track by a couple of millimetres that I had to use some sort of underlay.
Cork was far too expensive for me, so I used EVA foam (Funky Foam), stuck to the board with PVA and the track then stuck to the foam with Copydex.
(Comes in rather bright colours, but I just paint it).
What's more, compared with cork, that green "underlay" is dirt cheap !!!
What's wrong with corrugated cardboard as a trackbed? One would have thought that, given its cellular type construction there might be some sound deadening qualities. It's cheaper than cork, in fact free, being thrown away by a supermarket near you. The sloping sides of the ballast can be made-up with something, possibly just a slither of card or even papier-mache?
One volunteer needed to give it a try and report back. I retain the right to receive any royalties when it goes viral!
Last edit: by col.stephens
