Edging
Hi Nigel. Thank you. I have never thought much about “statistics†, I purchased Hornby system 4 or 6 to prove that.Then someone recommended Graham Farish OO Points, another bod said “ you should have bought Peco “ . And all that was fifty years ago. Your comment “ And that the curves for getting the exit track parallel “ , that is what I thought was I idea of the asymmetric point. But, wrong again. Best wishes. Kevin
Hi Kevin,
There are lies, more lies, and then there are statistics. Expert opinion is usually…not. Run a mile when you get expert opinion on matters statistical. When you have controlled every variable and it still doesn't work, the first person to have a look at it will point out the obvious error. Or it will work. Sometimes.
On any point you will need some space immediately after the exit to allow for clearances. It can be quite a lot.
Taken from the "Worm Runner"s Digest". Circa 1964-5, which tabulated Bugere's, Murphy's and Sod's laws. I take solace in the fact that one of the most used (and abused) statistical tests, Student's t-test, was formulated by an employee of the Guinness brewery in Dublin. Presumably it involved extensive testing and sampling.
Farish points - better looking than the Peco ones. As was the track.
