CORK
I am also thinking of laying a complete layer of tiles as a base on top of my modules to allow 3.2mm or so for running point/signal cable runs for manual operation. The track bed itself would be another 45mm wide strip on top of this.
The 3.2mm depth may also help with building/platform mounting adjustment etc.
In my view they are great because you can cut them to virtually whatever size you want - they are usually 1 metre wide. :lol: :lol:
I've laid yards of track with the stuff which is easily available here in Spain in rolls (I think they make it here) but that means that I cant help you with prices etc assuming you are in the UK.
The most interesting place I found the roll useful was in laying cork down at my 7 road station. I laid the whole width across the baseboard because I needed ballast almost level in the station area (and to put the platforms on) and then gradually cut the piece to form ballast under each track as it left the station area - easy. :lol: :lol:
Les
Devon Junction
Kernow Junction
Kernow Junction
Matt, the cork rolls available here are 50cm wide x 8m long - i.e. 4 sq.metres. They are avaialble in 2mm or 4mm thickness and are very slightly cheaper than the equivalent 300mm square tiles. The tiles work out at 6 euros 50 per sq. metre and the rolls at 6 euros 15 per sq. metre. If you've got a calculator, a euro is about 67p. How does that compare with UK prices ?
Les, your rolls are wider than those I saw here - don't know where they come from but I suspect maybe the cork trees in Portugal. The quality of the cork looked identical to that of the tiles - nice and soft and fairly small grain so less likely to break out when cutting. Are your rolls in both 2mm and 4mm thickness ?
Jeff - I just bought a couple of small packs of tiles - just a tad under 2 sq. metres to try. I'm still not sure if 2mm will be thick enough to kill the sound on chipboard but I do understand what you say all about 4mm being too thick. When I suggested double thickness, I was thinking about totally covering the boards with 2mm and then using 2mm as a track bed thus giving 4mm under the track - if you see what I mean :roll: :roll:
Petermac
Petermac
Of course Bob is right, to use 2mm everywhere and then an extra 2mm under the track would be an excellent solution.
If I was starting again, I would do the same with my 3.2mm tiles :!: :!:
It would be a good idea to accurately cut out the footprint of a building from the 2mm cork covering and sit the building into the cut out.
This would easily get rid of the join-line along the bottom of a building, that looks so unsightly untill scenically treated, although you would have to be careful not to "bury" your door sills below ground level :!:
Petermac
The roll I have used is 3mm thick, but I do know that there is a slightly thicker one which I presume is 4mm. Bob probably knows - are you thinking of nipping over the border to get some? :lol:
Les
Devon Junction
Kernow Junction
Kernow Junction
Les said
Petermac wroteAre your rolls in both 2mm and 4mm thickness
Les
Les - could be !! Everything seems cheaper in Spain than here - particularly the booze !! We do get down to the border at Hendaye a couple of times a year to stock up and I may pop down as far as San Sebastian to see what's on offer. The Med. coast of Spain is quite a bit further than the Atlantic coast for us - Barcelona is about 6 hrs via the motorway whereas Hendaye is only some 4 hours but the cork may be worth looking at !!!
Petermac
Les
Devon Junction
Kernow Junction
Kernow Junction
No, I'd have to make some excuse like maybe "handbags are cheaper in Spain dear - would you like to go and have a look ?" Quickly followed by "Oh good heavens ! - look there's a cork shop, what a surprise !!"
Do you think that might work ? On the other hand, I may follow your suggestion and bring it back from the UK - as a lifejacket you'll understand - just in case the 'plane ditches !!! I'm leaving on Tuesday until mid November so we'll see what transpires.
Petermac
Les
Devon Junction
Kernow Junction
Kernow Junction
Off tomorrow - back mid November
Petermac
