BASEBOARDS (and site of)
(In Topic #730)
Does anyone else have experience of a garage location or any thoughts on same?
Ken
My garage offers me a workbench and the space for a fairly large layout and although dry I have found it to be damn cold over these winter months resulting in no work being done on it since late October. I have thought about putting a small heater in there similar to that which is located in both the greenhouse and the summerhouse but not sure if it is adequate.
In the spring I plan to plasterboard the roof above the layout and the surrounding walls and put in some insulation. I have thought about putting in a false wall so that the layout becomes enclosed but I doubt whether the local clerk of works (she who must be obeyed) would sanction such a move.
I am putting a small workbench in the small bedroom which I currently use as a study where my IT "stuff" is which will allow me to model without having to be in the garage all the time. In any case I have to teach myself how to solder which will require a considerable amount of practice over the coming months before I venture anywhere near the layout with soldering iron in hand.
I think what I am trying to say is that the garage was really the only option for me as I cannot use the loft area due to beams etc. and was well aware of the potential pitfalls regarding the winter months so I am compromising …… Doing scenery, wiring and "testing" during the warmer months and modelling indoors during the colder months.
I have maybe bitten off more than I can chew by doing such a big project but small ovals, single planks didn't "shuffle my cards" although I am very impressed at some of the displays I have seen.
Happy modelling
Matt (perth Buddy)
Matt, we are very much on the same wavelength here on everything you've said (even down to the loft problem) so I sympathize with you on all counts. I've always thought that the biggest put-off for railway modelling is not having a suitable space: most of us have ideas well above our station (pun intended!) so having to reduce our layouts is a real drag, still, these hang-ups do make us think of different ways to get around the problem and that has to be good.
Ken
Robert said
Just how much space do you have access to in the spare bedroom Ken, and will it be permanent space?
Bob, I can run it around 2 walls as an "L" shape 8'6" and 6'0" x 2'0" (plus I could add an extra 6'0" "leg" making it into a "U" shape which would go under the window and over the radiator). I am thinking of a branch line station (terminus) at one end probably going to a fiddle yard. By permanent I assume you mean fixed to the wall and my answer is "I think so"!!! Trouble is this is also my music room and my Vibes (Vibraphone) takes up a lot of space - in front of the window(!!!) plus I have the occasional rehearsal with two other musicians - Double Bass and Guitar - so a bit tight!!! (I've also got a synthesizer and another keyboard but they're packed away in the wardrobe, but, if my pianist was to come round too…….!!!).
You can see why I'm taking my time with the planning, but I think the "L" shape will have to be the one, certainly to start with.
Ken
