Baseboards
(In Topic #12076)
How to pack a basebofor transport?
Hi All. I am not expecting to have trains running (any day soon?) on my main baseboard , And in the meantime they the modules, that is, have just been too handy to use as workbenches.but it may be necessary to pack them together as if it was going to an exhibition. Because it is, it takes up a lot of room(just doing nothing). But one day soon I hope to have it up and running, Each of the modules are 3ft 8 inches by 2 ft. I have seen them joined ( surface to surface) and bolted with plywood spacers, but, how far apart do they have to be for scenery? all the best. Kevin
An overbridge would be around 75mm above datum but surely, you'll have some landform or buildings at track level :hmm
To work out how far apart the boards would need to be when packed face to face, is to measure the tallest bit of scenery/tree/building/telegraph pole etc. on each board then add, say,15mm for a safety margin and that's your distance.
For example, on the left hand board, you have a tree at track level - i.e. track level (to allow for the overbridge) is 75mm above datum, the tree is say another 75mm so that's 150mm total height above baseboard surface. Do the same calculation for the right hand board, add around 10 - 15mm for safety and that's your distance apart when packed face to face. You can soon end up with a fairly hefty sandwich ……………….. ;-)
I wouldn't worry about it too much, get your main scenic features done and then you can work out how big the end plates need to be.
Backboards? Are you planning on having them? If so just make them removable.Make tall structures and trees removable as well. Otherwise you will need a pantechnicon to move them.
Give me their names and addresses and I'll send someone around to sort them out. :cool:
Who are these critics, Kevin?
I'll bet they also use suitcase connectors …………………….. :pedal
KevinHi Kevin,
I would disagree with Nigel on this matter. Having dismantled and stored my layout regularly between exhibitions and whilst working on it over the years, I would not make things removable for storage (to work on is a different matter). Every time you remove something the risk of damage is high and each bit has to be carefully stored and the same goes for when it is taken out of storage and replaced on the layout. All time consuming and it becomes a real chore.
I only mentioned exhibiting to make the point. I have had to take Much Murkle up and down many times and I'm always looking to minimise the work involved and the risk of damage. It would be no different if I was doing it in the home environment. :)
Each board is 5" deep and the backboard extends 10" above the top.
When crated, two boards bolt together with end plates as I described before and the box it makes is approx 4'1" x 2'3" x 2'. The third board has a front and end plates bolted to it to make a box which is approx 4' x 1'3" x 2'.
Despite what I said about not have things removable on the layout there are of course a myriad of other things that need to be boxed up when stored, controllers, stock, in my case, cassettes, lighting, legs etc.
The layout is erected at the moment getting it ready for a show so I can't photograph it packed away.
all the best. Kevin
