Baseboards
Too much plywood
Hi Kevin,Nine times out of 10 it's not.
He will cut 8' x 4' boards into strips for me very accurately. Then I have a compound radial arm saw for cuts up to a foot long.
With the saw, 16 mm thick MDF can be cut into blocks for holding things square while glue sets up. Working on a piece of 1/4" plate glass helps as well.
The staff at my local big chain hardware store may or may not know how to the use the equipment. Last time I was there I had to show the "associate" how it was done. He'd never heard of a squaring cut.
Hi Bill. This is another reply, of an old thread “ Baseboards “ and now that I have settled for “ Planks/ modules “ I am uncertain about legs. I have been considering a wallpapering table, or two? If I could build sturdy lightweight wooden trestles, all the same height that would be superior. The ones sold by Screwfix are “over the top “. They don’t have to be very wide, just steady. But then I would be able to lose the overweight benches that take up so much room. A sort of decluttering, and it would make the room look bigger. Best wishes Kevin
Surely you're not really going to scrap all your baseboards and start over from scratch Kevin? Considering how long it's taken to get to the stage where everything works and you've started scenic work and now considering buildings, it would be a waste to throw it all away for the sake of finding a few decent trestles.
Forget folding wallpaper tables. They're not stable and will support hardly any weight. I buy folding timber trestles from local DIY stores from 5 to10€ and find them fine for all sorts of jobs, from supporting baseboards to a heavy 4 metre long table-top we use for seating a dozen people for outdoor dining in the summer. I have folding plastic ones as well, but timber is far more stable and therefore safer.
Timber trestles seem to have been largely superseded by the horrid plastic ones in UK DIY stores, but alternatives to everything in life can be found with simple internet searches.
Take a look at IKEA for instance, who do a range of timer trestles and there will be a shop not too far from you:
https://www.ikea.com/gb/en/products/desks/table-tops-legs/lerberg-trestle-white-art-50165003/
The one above are just £5 each and the photo shows how they are correctly used in pairs, or:
https://www.ikea.com/gb/en/products/desks/table-tops-legs/oddvald-trestle-black-art-10118971/
This is of more traditional design and still inexpensive at £10 and will be build to IKEA's exacting standards. Both types are 70cm / 27" high.
Bon courage,
I believe that there is a new lkea opening nearby? The only other one I visited was in Croydon , a train and tram ride away. But I will investigate the possibilities. Best wishes Kevin
If cost is an issue go to a local charity shop who does furniture im sure one of them will have a folding leafed dining table which will be fine for your baseboards at a very small cost.
Last edit: by Briperran
