Baseboard alignment dowels 'on the cheap'.......
(In Topic #2155)
Or..'.save money for Scottish Laughing Water!'
Seehttp://yourmodelrailway.net/view_topic.php?id=12881&forum_id=21&jump_to=227469#p227469
Post #0
I HAD HOPED TO MAKE A REPLY TO A MARTYS QUESTION IN 'NEW END Post 14' BUT ENDED UP BUMPING THIS WHOLE TOPIC
.Like several other members, I have decided to make my base boards in sections, in my case 4 off, 4ftx1ft-8". I've used a 4mm 'I' beam frame overlaid by ply, but for ages, I've been pondering a low cost, low tech equivalent to those expensive dowels used by some here………..as SWMBO works on the principle that '£X spent on modelling= 2 x £X spent on clothes, shoes, and luxuries like food' etc…
I only want reliable alignment for the occasional disassembly/reassembly, not a hard wearing device suitable for the exhibition circuit, so, after 2 years, a brain-wave.
Copper pipe here in France is supplied in 10, 12, 14, 16mm sizes, which all fit precisely inside each other, indeed, to make a 14 to 12 reduction, there is no need to buy a purpose made adaptor, it is sufficient to insert one into the other…still with me?
In UK, or elsewhere, probably, the same relationship would exist between, say, a piece of 15mm pipe, and a plain connector.
I took a short piece of 16mm pipe long enough to bridge two adjacent boards, cut it in half, and soldered one piece to a length of 14mm [see photo 1]
Then I slid the loose piece over the 14mm pipe to lie alongside the soldered piece, cut the whole free from the 14 mm pipe and tapped it into a tight fitting hole drilled squarely through both halves of the boards which were tightly clamped in alignment.
Before doing so, I smeared the inside of the hole with PVA, and roughened the outside of the 16mm pipe with a hacksaw blade. [See photo 2}
After several hours, I was able to separate the boards, leaving the soldered 16/14mm piece in one board, and the second piece of 16mm in the other board. [See picture 3]
You may have noticed [Picture 1] that to hold adjacent boards together, I have used some of the screw fittings used to secure head boards to beds, having scrounged a few from a furniture store in UK. In case you are not as brass-necked as me, I have included a picture of an alternative home-made thumbscrew, soft soldered from a penny washer and a bolt after cutting a groove in the head with a hacksaw. They other ends screw into a suitable nut, soft soldered to a washer, drilled for mounting screws.
I hope this helps someone, and avoids the need to buy so many compensatory Marks and Spencers vouchers for SWMBO [or HWMBO…]
:doublethumb;-):lol::lol::lol::lol::cool:
The only downside I see is if moving them around as separate modules, you would have to be careful that the copper projection was not hit & bend slightly because it would be a devil of a job to get it back in alignment properly again without a lot of effort.
The ends are turned over so that you don't spike yourself when fumbling under the board [I've been known to fumble a lot….]
I shall shorten the long spigots on the original model to about 1/4", adequate for alignment, yet not too long so as to be vulnerable.
PSI'm in SWMBO's good books because I took her acup of tea in bed at 0725……….
Separated
Assembled, but not inserted in place
Mark 2 is born and "the dog" has cracked it :exclam:exclam
Nice one Doug :thumbs:thumbs:thumbs
Do I get some royalty payments for saying that I see a problem:question
Separated"
Obviously she wanted coffee.
