Started a backscene
(In Topic #8177)
Its a ceiling high scene and this is the first corner of the layout.
Started off with sky
Then moved onto some hills and fields
Any tips would be much appreciated.
Barney
Barney
Bob
how did you do it Shaun?
I did the sky first, the blue is a mix of ultramarine and cobalt blue, I started at the top and worked my way to the bottom adding more white as I went down. While the sky was still wet I did the clouds, lightly spread some white paint on with a brush and then used my finger to blend in the clouds.
For the landscape I started with a light green base, then added the fields and trees/hedges between them. I used my finger dipped in water to blend the top of the hills into the sky. I will probably touch it up more again though.
Nice big back scene makes a big difference to a layout.
Kim
