TwoBolt John`s 7mm MR/LMS wagon builds
(In Topic #12121)
white metal and plastic kits mainly
I`m planning some kind of layout project 1930`s MR/LMS and am in the process of building locos and stock.I`m going to move away from having the usual good shed scene and thought I would model a small moving yard crane.
I`m predominantly a kit builder in these matters and went for a Meteor models kit which looks as if it is based on MR practice.
The white metal crane was quite good and by chance made it to actually work. The truck it sits on however, needed replacement W irons from Slaters and was awkward to make…………
The truck was a soldering project and the crane was assembled with Gorrila superglue……………………
Next will be a MR shunters truck………
Sometimes, chance finds on ebay come up. I came across three Oldbury Models whitemetal wagon kits recently all less than £20 each.
This company is gone now and I find making whitemetal kits quite therapeutic.
The castings are not the best I`ve ever seen and needed alot of cleaning up with knife blades and fibre brushes.
The solebar castings have a bow in them and so need gently straightening out.
But except for wheels ( I used Peco) they are complete kits with sprung buffers(whitemetal though)…….
Soldering the handrails was a challenge to keep square and I replaced the whitemetal foot boards with brass angle.
I used Carrs 100deg low melt solder as it does`nt need tinning.
Except for locomotive kits I`ve moved over to Clostermans black etch primer for everything else. It`s a quality spray can item that does`nt flood your model with too much paint and saves using and then cleaning an airbrush.
Finally…….. two coats of Humbrol No85 black with an airbrush ( Humbrol does`nt seem to dry very quickly if you brush it on)
Transfers fromn a 30 year old set of 4mm PC methfix transfers and based on photos in Midland Wagons volume 1
Last edit: by Twobolt
Twobolt John
I love the shunters truck - not as common as on GWR.
I also tend to replace footboards with brass, plastic (in my case) is just too fragile.
I`ve got a Parkside/Dundas O Gauge MR Brakevan in the paintshop but I hav`nt changed the footboards on that. The
lampirons and handrails are also fairly fragile. I`ll just have to treat the wagons as kindly as the locos.
At the moment I keep all wagons and vans in soap or ice cream boxes………….
Twobolt John
This is the Parkside GW…………………………………….
some of the lamp irons on this one Ihave had to retro fit with home made brass. So long as you make sure the footboards are absolutely straight and no twists the Plastic Weld seems to hold strong.
The Peco( ex Richard Webster) brakevans seem to be made from stronger plastic…………..
Twobolt John
Best of Luck from a cold 0c South Wales
Noviceman
Superb examples of kit building that I could never hope to match in a million years.
Allan
Last edit: by allan downes
:thumbs :thumbs ;-) :cool:
Owen
if the lights are off no cam
Morning Kevin,
I`ll do my best……….
What kind of kit?
Twobolt John
Kevin
make sure you have a 25watt soldering iron. If your thinking of having a second think about a 40watt as well (I use antex irons)
And as others have said, a method of cleaning and tinning the tips regularly.
The small whitemetal parts don`t need to be soldered so use a quality superglue.
just ask away if you need advice…
john
Twobolt John
