Minimum Radius Curve in Gauge 0
(In Topic #13445)
Track construction.
Many years ago I ran Hornby Clockwork Tinplate which had 2ft radius curves, Now ACE trains make a fabulous 'Duke of Gloucester' in gauge 0 which will also go round 2ft radius curves, looks silly some might say but at an exhibition the sheer size of it creates its own illusion - and it works! However, has anyone any idea what the minimum radius a Dapol 0 gauge Terrier will negotiate? Minerva models state that their Gauge 0 Locos will negotiate Peco gauge 0 setrack which are a tad over 40" radius - they are intriguingly marketed as No2 Radius, what is No1 Radius? What radius for example was the old lima 0 gauge curves and will a Dapol Terrier negotiate it? Any ideas anyone?Thanks
Simon.
Oh well back to the asylum
Peco technical information that is available shows both the Setrack points and the ST725 curves are 1028mm (40.5 inches) radius. The curves and the points rotate through 22.5 degrees - the same geometry as OO and N gauge I believe.
1028mm x 4 / 7 = 587mm or about 24 inches - In OO gauge the Settrack 2nd radius is 17 1/4 inches so the O gauge one is a lot wider - more akin to Peco Streamline small radius pointwork which is a nominal 2ft radius.
I know this doesn't answer your question but it might imply that any short wheelbase 6-coupled engine will be fine on the 7mm Setrack curves.
