Video Archive | Recent Topics |
Moderated by: Spurno |
Scalescenes Large Station Building - Scalescenes Building Kits. - More Practical Help - Your Model Railway Club | ||||||||||
Author | Post | |||||||||
Chinahand Full Member ![]()
My photos:
I've looked through the Scalescenes section and can't see any photos of the Large Station Building so thought a few pictures might be of use to someone. This is an N Scale model and is actually an 'extended' version of the kit with additional bays fitted at both ends to produce an overall building length of 220mm (32.5 metres at 1:1). It was originally intended as a Terminus Station for the large layout I had planned to build in China but is probably surplus to requirements now. Building it was all good practice though. The Road-side Facade ![]() The Track-side facade with Arrivals and Departures Boards added ![]() ____________________ Regards, Trevor |
Bikeracer Former Member
My photos:
Hi Trevor, Interesting variation and now I know what the back looks like. Is the clock tower a separate module to the main building? I've built the medium station,but it doesn't seem quite right for use with the canopy. Allan |
My photos:
Hi Allan, Yes the clock tower is a separate module but there is an opening into it at 1st floor level of the main building that you would need to close off if you didn't have the tower there. John Wiffen designed the Overall Arched Roof to go with this station building not with the medium one. There is also an additional free 'steps' module that raises the whole building up to platform level with a very grand set of steps at the front of the building. ____________________ Regards, Trevor |
My photos:
Looks like I'll need to build the large station then to get something suitable. My station is a through one,so I'll have to see how it fits on the side of the canopy rather than the end. I'll download the station later and have a look at the construction of it,but I really need to finish laying my goods yard before I start any more buildings. Allan |
My photos:
I've downloaded the station and can now see how it fits on the side of the canopy. There are a lot of parts to make. ![]() Allan |
new04db Lurking Around the Forum ![]()
My photos:
those arrival and departure boards, did you make them or do the come with the kit?, just wondering as I spent hours making a 00 gauge arrival and departure board and if I could have just got one from scalescences I will kick myself
____________________ Kind Regards Aaron Kingsmead Station ©Aaron C. New |
My photos:
Sorry Aaron, I made them myself in an MS Excel spreadsheet using black background with white text and cell borders.
My photos:
No kicking for me then ![]() ![]() ____________________ Kind Regards Aaron Kingsmead Station ©Aaron C. New |
col.stephens Full Member
My photos:
You have made a very nice job of that building, Trevor. What thickness of card are you required to use? Terry |
My photos:
Hi Terry, There is quite a bit of tolerance in the Scalescenes kits when it comes to card thicknesses. Personally, bearing in mind this is N Scale, I use a hard 1mm card for the main walls, 200 gsm thin card for things like roofs and 100 gsm textured paper for cover layers. The hard card I use is actually photo album card which I've found is quite a bit more rigid that normal card. It does blunt craft knife blades quite quickly though. ![]() The station building outer walls were just made up in 2 layers but I've recently started using Brassmaster windows which necessitate using a third centre layer with over-sized cut-outs for the etched brass windows to sit in so that they don't cause the walls to bulge. ____________________ Regards, Trevor |
My photos:
Thanks Trevor. Although I'm currently modelling in 4mm scale, I might make one of the Scalescenes buildings in 2mm scale just for the fun of it. Terry |
This is topic ID = 9982 Current time is 02:20 pm |
You are here: Your Model Railway Club > More Practical Help > Scalescenes Building Kits. > Scalescenes Large Station Building | |||
You can type a quick reply to this topic here. Click in the box below to begin. Or to reply to an individual post, or to include images, attachments and formatted text, click the Quote or Reply buttons on each post above. To start a new topic in this forum, click the Start New Topic button below. To start a new topic in a different forum, click the Forum Jump drop-down list below. |
Back to top of page | ||
Problems with this web site? Please contact the Webmaster. |
All material submitted to this web site is the responsibility of the respective contributor. By submitting material to this web site you acknowledge that you accept full responsibility for the material submitted. |
Unless stated otherwise, all the material displayed on this web site, including all text, photographs, drawings and other images, is copyright and the property of the respective contributor. Registered members are welcome to use it for their own personal non-commercial modelmaking purposes. It must not be reproduced or re-published elsewhere in any form, or used commercially, without first obtaining the owner's express permission. |
The owner of this web site may edit, modify or remove any content at any time without giving notice or reason. © 2008 |
Recent Topics | Back to top of page | |
Powered by Copyright © 2007-2011 by Jim Hale and Data 1 Systems. Page design copyright © 2008-2013 Martin Wynne. Photo gallery copyright © 2009 David Williams. |
