Video Archive         Recent Topics
YMR logo
You are here:  Your Model Railway Club > More Practical Help > Scratchbuilding. > Scratchbuild To bottom of page
 Moderated by: Spurno
Start New Topic Reply Printer Friendly
Scratchbuild - Scratchbuilding. - More Practical Help - Your Model Railway Club
AuthorPost
 Posted: Mon Aug 20th, 2018 02:40 am
PMQuoteReply
link to this 1st post
Passed Driver
Status:
Offline
My photos:
view photos in Gallery
view photos as slides
Hi All.   Even train staff, are not expected to “crunch ballast “ as they walk to prepare , or from the depot, after disposal, of their trains. So how can I Scratchbuild a footpath beside the tracks on my layout??? Any advice would be welcome .     Best wishes .  Kevin
____________________
Back To Top PMQuoteReply
 Posted: Mon Aug 20th, 2018 08:30 am
PMQuoteReply
link to this 2nd post
The Q
Location: Somewhere In Norfolk, Or Maybe Scotland, United Kingdom
Status:
Offline
My photos:
That depends on your period of modelling, quite often in the past railway staff were expected to crunch the ballast.
 However, in steam days ballast around a shed was often covered with, mixed with,  or made of ash from the locomotives.
 Today there may be a concrete path. unless for some reason it has to be raised, then to day it would be a metal  grating in the past it would be wood.
For a ground level path for both ash and concrete I would use pollyfilla, suitably painted, but the ash would have something slightly grainy added on top.
For a wooden raised path then plasticard scribed or bought embossed. For Metal gratings then your only choice is  some etched brass
Now I've finally started a model railway...I've inherited another...
 Posted: Mon Aug 20th, 2018 12:33 pm
PMQuoteReply
link to this 3rd post
Passed Driver
Status:
Offline
My photos:
Hi the Q.  Thank you for your reply. As it so happens, I have got a bag of “Ash?” from a famous manufacturer, and I have a “£1.00” shop tiub of their filler, which I may experiment with , a filler and ash combo? Whether or not I can press the ash into the filler? I don’t know , but, it is an idea.   Best wishes. Kevin
 Posted: Wed Aug 22nd, 2018 02:28 am
PMQuoteReply
link to this 4th post
BCDR
Moderator
Status:
Offline
My photos:
Hi Kevin,
N-scale cinders or ballast are too big for walkways, and fine sand looks terrible. Put N-scale cinders or ballast in a herb chopper or coffee grinder, and give it a whizz for 15-20 seconds or so. Paint desired path with white glue/IPA/water (75/10/15 by volume), sprinkle ground-up ballast on top, leave to set. The alcohol pulls the PVA up by capillary action and evaporation. Mist with water/IPA if desired to help things along. Avoid washing up liquid, if you must use it unscented and cheap is best. Otherwise your layout will smell of spring garland or summer glory for months. Learned this off Brossard.
 Posted: Wed Aug 22nd, 2018 06:35 am
PMQuoteReply
link to this 5th post
Passed Driver
Status:
Offline
My photos:
Hi Nigel.  Thank you for you reply. Sounds a good idea, I have a herb chopper, that I purchased for chopping cinnamon , would it be easy to clean? after the event. You didn’t think much of the £1.00 shop filler idea then.Best wishes.  Kevin
 Posted: Thu Aug 23rd, 2018 08:37 am
PMQuoteReply
link to this 6th post
xdford
Member
Status:
Offline
My photos:
HI Kevin,
Have a look at the thread on the St Agnes.  There is a waste material that you should be able to get at a picture framers that Foam Core sheets come separated by and my local picture framer is more than happy to give it to local modellers. It cannot be recycled any other way and will wind up in land fill.
It is literally a wafer thin foam sheet that can be easily cut with scissors and has a texture like a rough concrete path but not the rough texture of ground down ground ballast, particularly for N scale.
I used it for the decking of my station platforms as well as concrete between rails in my engine depot area. The cost was right so all I have to do is paint it... which I will get on and do.  If you want, I can take a pic or two to show you the stuff.
In the past I have tried to recycle foam cups n HO which in small interlocking pieces glued flat looks very representative of cobblestone but for N I think it would look too thick.
Anyway, my two cents/pennies/rupees/lira/whatever worth!
This is topic ID = 15739     Current time is 08:15 pm
You can type a quick reply to this topic here. Click in the box below to begin.
Or to reply to an individual post, or to include images, attachments and formatted text,
click the Quote or Reply buttons on each post above.
To start a new topic in this forum, click the Start New Topic button below.
To start a new topic in a different forum, click the Forum Jump drop-down list below.
Start New Topic
Back to top of page
15 Most Recent Topics
Problems with this web site? Please contact the Webmaster.
All material submitted to this web site is the responsibility of the respective contributor. By submitting material to this web site you acknowledge that you accept full responsibility for the material submitted.
Unless stated otherwise, all the material displayed on this web site, including all text, photographs, drawings and other images, is copyright and the property of the respective contributor. Registered members are welcome to use it for their own personal non-commercial modelmaking purposes. It must not be reproduced or re-published elsewhere in any form, or used commercially, without first obtaining the owner's express permission.
The owner of this web site may edit, modify or remove any content at any time without giving notice or reason.    © 2008
Recent Topics Back to top of page
Powered by UltraBB 1.15 Copyright © 2007-2011 by Jim Hale and Data 1 Systems. Page design copyright © 2008-2013 Martin Wynne. Photo gallery copyright © 2009 David Williams.
